Zum Hauptinhalt wechseln
Einleitung
Follow the steps in the guide to replace the display or broken glass.
After these essential steps you can proceed to disassemble the device for other repairs.
  1. Remove the back cover.
    • Remove the back cover.
  2. Remove the battery. Remove the SIM card and SD card.
    • Remove the battery.
    • Remove the SIM card and SD card.
  3. Heat the display edges adequately at 80 degrees Celsius (176°F), then proceed to detach the display by inserting the flat opening tools between the display glass and the frame. Be careful not to rip the flat cables that lie underneath the lower part of the phone, near the keys Be careful not to rip the display flat connectors that lie underneath the upper part of the phone
    • Heat the display edges adequately at 80 degrees Celsius (176°F), then proceed to detach the display by inserting the flat opening tools between the display glass and the frame.
    • Be careful not to rip the flat cables that lie underneath the lower part of the phone, near the keys
    • Be careful not to rip the display flat connectors that lie underneath the upper part of the phone
  4. !!!!CAUTION!!!! The display is also pasted in the middle with strong double-sided, be very careful if the display is not broken and you have to replace it with a new one. Insert translation here
    • !!!!CAUTION!!!! The display is also pasted in the middle with strong double-sided, be very careful if the display is not broken and you have to replace it with a new one.
    • Insert translation here
    • pink stripes are part of very strong adhesive that is likely to break the display
  5. remove black cap interlocking covering the display connector unhook the display connector unhook the display connector
    • remove black cap interlocking covering the display connector
    • unhook the display connector
  6. Separate the display and swap it out for a new one.
    • Separate the display and swap it out for a new one.
Abschluss
To assemble the device, follow these instructions in reverse order.
38 weitere Nutzer haben diese Anleitung absolviert.
Besonderer Dank geht an diese Übersetzer*innen:
it en
100%
Diese Übersetzer*innen helfen uns, die Welt in Ordnung zu bringen! Wie kann ich mithelfen?
Beginne zu übersetzen ›
Smilzo
9.307 Reputation
38 Anleitungen geschrieben
slt le problem que j ait un sm- g800f copy
c est pas originale et j arive pas a trouver l aficheur qui ce convien a lui
j besoin de votre aide pour avoir un aficheur pour tlphon portable sm-g800f fcc id:a3lsmg800f made korea by samsung
DJAMEL - Antwort
essayer d'expliquer avec des mots corrects, parce que le traducteur ne comprend pas ce que vous dites
Smilzo -
Not sure, but it sounds like he's looking for a display to fit a Samsung Galaxy S5 Mini (sm- g800f) that may or may not be a fake? There are a lot of shorthand and typos in there though...
Sam Goldheart -
Je suis désolé, je ne comprends pas
Smilzo - Antwort
There are typos, I personally buy spare parts on eBay
Smilzo - Antwort
Kommentar hinzufügen
Statistik anzeigen:
Letzten 24 Stunden: 2
Letzten 7 Tage: 15
Letzten 30 Tage: 110
Insgesamt: 37,639
