Zum Hauptinhalt wechseln
Sandal Brooch Replacement
Was du brauchst
  1. Sandal Brooch Replacement, Brooch: Schritt 1, Bild 1 von 3 Sandal Brooch Replacement, Brooch: Schritt 1, Bild 2 von 3 Sandal Brooch Replacement, Brooch: Schritt 1, Bild 3 von 3
    • Unwind about 10" of thread. Cut and thread through the needle. Tie a double knot at the end of the thread.
  2. Sandal Brooch Replacement: Schritt 2, Bild 1 von 2 Sandal Brooch Replacement: Schritt 2, Bild 2 von 2
    • The threads and empty holes show exactly where to attach the shoe ornament.
    • Cut off the old threads.
  3. Sandal Brooch Replacement: Schritt 3, Bild 1 von 2 Sandal Brooch Replacement: Schritt 3, Bild 2 von 2
    • Start the threaded needle on the upper side of the sandal.
    • The ornament will hide the knot.
    • If pushing the needle through the sandal strap is difficult, you might try turning the sandal at an angle and using your flat surface as a pressing point.
  4. Sandal Brooch Replacement: Schritt 4, Bild 1 von 1
    • Pull the thread through the ornament's opening.
    • Be careful—needles are sharp!
  5. Sandal Brooch Replacement: Schritt 5, Bild 1 von 3 Sandal Brooch Replacement: Schritt 5, Bild 2 von 3 Sandal Brooch Replacement: Schritt 5, Bild 3 von 3
    • Pull the thread down and through the sandal straps.
    • Repeat the process, catching the ornament in a variety of places to anchor several sides.
  6. Sandal Brooch Replacement: Schritt 6, Bild 1 von 2 Sandal Brooch Replacement: Schritt 6, Bild 2 von 2
    • Pull the thread so that the ornament is tight against the sandal.
    • Remember to beware of that sharp needle!
  7. Sandal Brooch Replacement: Schritt 7, Bild 1 von 1
    • Run the needle back through the sandal strap, then tie a knot at the base of the thread.
    • Double the knot before using your scissors to cut the thread.
    • Cut the thread just above the knot.
    • Be careful—scissors are sharp.
  8. Sandal Brooch Replacement: Schritt 8, Bild 1 von 1
    • Completed sandal—ready to wear!
Abschluss
Enjoy wearing the sandals!
KaC
157 Reputation
1 Anleitung geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 19
Insgesamt: 80
