Einleitung
To replace a faulty microphone follow the steps in this guide. This may be your only option if you find yourself unable to make voice recordings anymore with your device.
Was du brauchst
Remove the battery compartment cover.
Remove the battery.
Locate the interlocking pegs along the seam of the device's casings.
Gently pry the pegs apart one at a time, working your way around the case.
The battery contact springs may prevent the case from separating.
Push the battery contact springs down through the hole in the case.
The casing protecting the USB and headphone jacks must be removed.
Locate and gently pry apart the two interlocking clips holding it in place.
The outer casings may now be removed and the MP3 player should separate.
Use the soldering iron to liquefy the solder connecting the microphone to the motherboard.
When not in use, be sure to always elevate the hot end of the soldering iron on a metal stand to prevent incidental burns.
With the new microphone in place, use the soldering iron and solder to create a stable connection between the motherboard and microphone.
Give the new solder time to cool and harden.
