Einleitung
This guide will show you how to remove the back wheels and axle of a Sanitaire SC684 Vacuum and replace them. For this you will need a replacement back wheel and axle part for a Sanitaire SC684. The wheels come attached with the axle and are removed and replaced together.
Was du brauchst
Lay the vacuum on its side.
Remove the two screws with the Phillips #1 screwdriver that are securing the axle of the back wheels.
Repeat for the other wheel.
