Zum Hauptinhalt wechseln
Werkzeuge
Keine Werkzeuge angegeben.
Ersatzteile
  1. Be sure to unplug vacuum before disassembling to prevent electric shock.
    • Be sure to unplug vacuum before disassembling to prevent electric shock.
    • Unzip the red bag.
  2. Identify the white bag liner in the red bag.
    • Identify the white bag liner in the red bag.
    • Behind the white bag liner, locate the hose connecting the white bag liner and the suction hole.
  3. Roll down the spring coil to remove the white bag liner. Remove the white bag liner from the red bag by pulling upwards firmly and it will detach from the black tube.
    • Roll down the spring coil to remove the white bag liner.
    • Remove the white bag liner from the red bag by pulling upwards firmly and it will detach from the black tube.
    • Throw away white bag liner.
  4. Replace white bag liner
    • Replace white bag liner
Abschluss
Caycie Pascual
1 Reputation
5 Anleitungen geschrieben
Cal Poly, Team 16-58, Forte Fall 2012 Mitglied von Cal Poly, Team 16-58, Forte Fall 2012
CPSU-FORTE-F12S16G58
5 Mitglieder
Kommentar hinzufügen
Statistik anzeigen:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 1
Insgesamt: 576
