Zum Hauptinhalt wechseln
Einleitung
This guide will give you step by step directions on how to replace a Sanitaire SC684 Belt.
  1. Be sure to unplug the vacuum cleaner before disassembling to prevent electric shock.
    • Be sure to unplug the vacuum cleaner before disassembling to prevent electric shock.
    • Lay vacuum on its back
  2. Find the bottom metal plate and identify the two latches on either side of the vacuum.
    • Find the bottom metal plate and identify the two latches on either side of the vacuum.
    • Detach the two latches on either side of the vacuum by pulling outwards towards the wheels.
  3. Android Fix Kits
    Ein neues Display oder Akku sind nur ein Kit entfernt.
    Jetzt kaufen
    Android Fix Kits
    Jetzt kaufen
  4. Lift off the metal plate by pulling it towards you.
    • Lift off the metal plate by pulling it towards you.
  5. Identify the belt and brush roller.
    • Identify the belt and brush roller.
    • The belt is a black circle made of rubber.
    • The brush roller has bristles and is tube shaped.
  6. Slide the belt off of the circular knob.
    • Slide the belt off of the circular knob.
  7. Pull brush roller out and detach the belt off the brush roller. Pull brush roller out and detach the belt off the brush roller.
    • Pull brush roller out and detach the belt off the brush roller.
Abschluss
Caycie Pascual
1 Reputation
5 Anleitungen geschrieben
Cal Poly, Team 16-58, Forte Fall 2012 Mitglied von Cal Poly, Team 16-58, Forte Fall 2012
CPSU-FORTE-F12S16G58
5 Mitglieder
Kommentar hinzufügen
Statistik anzeigen:
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 12
Insgesamt: 2,012
