Ersatzteile
Keine Ersatzteile angegeben.
Using a plastic opening tool, lift the metal backing from the front of the device.
Grip the bottom of the battery with your thumb and forefinger and pull it away from the device.
Flip the device so that the front is facing you.
Slide a plastic opening tool between the plastic front cover and the metal back cover of the device.
Gently pry the bottom of the black button to remove it from the device.
To remove the white scrolling mechanism, remove two of the bottom hooks using a spudger.
Clean the area around the button to remove any dirt or other outside material that would prevent the scroll wheel from moving freely.
6 weitere Nutzer haben diese Anleitung absolviert.
Ein Kommentar
Thanks very much for this guide. I used it to expose and clean my Sansa scroll wheel which is now functioning much better.
