Zum Hauptinhalt wechseln
Sanyo Katana Microphone Replacement
Was du brauchst
  1. Sanyo Katana Microphone Replacement, Battery: Schritt 1, Bild 1 von 3 Sanyo Katana Microphone Replacement, Battery: Schritt 1, Bild 2 von 3 Sanyo Katana Microphone Replacement, Battery: Schritt 1, Bild 3 von 3
    • Place thumb on the tab located at the back of the phone and slide button towards your hand and away from phone.
    • While holding down the button, pull cover off with other hand.
  2. Sanyo Katana Microphone Replacement: Schritt 2, Bild 1 von 3 Sanyo Katana Microphone Replacement: Schritt 2, Bild 2 von 3 Sanyo Katana Microphone Replacement: Schritt 2, Bild 3 von 3
    • Use fingers to grip the battery and remove it from the phone.
  3. Sanyo Katana Microphone Replacement, Back Casing: Schritt 3, Bild 1 von 1
    • Using a spudger, remove the four rubber coverings on the lower back plate.
  4. Sanyo Katana Microphone Replacement: Schritt 4, Bild 1 von 3 Sanyo Katana Microphone Replacement: Schritt 4, Bild 2 von 3 Sanyo Katana Microphone Replacement: Schritt 4, Bild 3 von 3
    • Using a Tri-wing Y0 screwdriver, remove the four 4.4mm screws securing the back plate.
  5. Sanyo Katana Microphone Replacement: Schritt 5, Bild 1 von 3 Sanyo Katana Microphone Replacement: Schritt 5, Bild 2 von 3 Sanyo Katana Microphone Replacement: Schritt 5, Bild 3 von 3
    • Remove the lower back cover to reveal part of the motherboard and the circular speaker housed in the back cover plate.
  6. Sanyo Katana Microphone Replacement, Motherboard: Schritt 6, Bild 1 von 2 Sanyo Katana Microphone Replacement, Motherboard: Schritt 6, Bild 2 von 2
    • Unscrew the 4.4mm screws at the top of the phone with the Tri-wing Y0 Screwdriver.
  7. Sanyo Katana Microphone Replacement: Schritt 7, Bild 1 von 3 Sanyo Katana Microphone Replacement: Schritt 7, Bild 2 von 3 Sanyo Katana Microphone Replacement: Schritt 7, Bild 3 von 3
    • For the following steps, the phone is shown closed to make manipulating the parts easier.
    • Using a spudger, remove the thin aluminum plate to access the upper motherboard.
    • This will most likely be difficult to pry off and will take a considerable amount of force. Stay clear of the piece to avoid injury when it comes free of the device.
  8. Sanyo Katana Microphone Replacement: Schritt 8, Bild 1 von 1
    • Use the flat end of the spudger to remove two ribbon cables from the back of the motherboard.
  9. Sanyo Katana Microphone Replacement: Schritt 9, Bild 1 von 3 Sanyo Katana Microphone Replacement: Schritt 9, Bild 2 von 3 Sanyo Katana Microphone Replacement: Schritt 9, Bild 3 von 3
    • Open the phone and firmly hold the phone casing with one hand and push the motherboard out of the case with the other by pushing on the keys.
    • Once the keys are free from the casing, close the phone and pull the motherboard from the back of the phone the remainder of the way with your fingers.
  10. Sanyo Katana Microphone Replacement, Microphone: Schritt 10, Bild 1 von 2 Sanyo Katana Microphone Replacement, Microphone: Schritt 10, Bild 2 von 2
    • Use fingers to grab the microphone and remove it from its housing.
Abschluss
Scott Perry
1 Reputation
1 Anleitung geschrieben
Clemson, Team 12-1, Benson Spring 2013 Mitglied von Clemson, Team 12-1, Benson Spring 2013
CLEM-BENSON-S13S12G1
4 Mitglieder
20 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzten 24 Stunden: 0
Letzten 7 Tage: 0
Letzten 30 Tage: 3
Insgesamt: 264
