Einleitung
This guide will show you how to properly install a camera for the Sanyo SCP-8100. If your device is having trouble taking pictures or it will not take pictures at all, you may need to install a new camera.
You will need to open the front panel and remove the LCD board in order to get to the camera piece.
Ersatzteile
Keine Ersatzteile angegeben.
Open the phone and remove the four stickers that hide the four 0.5 mm screws.
On the bottom two, use a push pin to pull out the stickers.
Use the Tri-Wing Y1 screwdriver to unscrew the now uncovered four 0.5 mm screws.
Use tweezers to detach the plastic connector.
With the tweezers, pull the wires from the plastic clamp.
Use plastic opening tool to pry the board off of the front panel.
Completely remove the screen from the phone.
Use the opening tool to take off the black plastic frame around the camera lens.
Lift the camera from the opening.
Detach and pull the camera from the ZIF connector.
