Einleitung
In order to replace the keypad, you will need to unscrew and pry the back panel off of the phone. The keypad is located underneath the motherboard.
- Note: In order to pull out the plug on the back of the phone that is hiding one of the screw, you will need to use a push pin. A spudger or opening tool are too thick to take it out.
Ersatzteile
Keine Ersatzteile angegeben.
Push and hold the button on the back toward the direction of the arrow to unlock the battery.
Lift and remove the battery from the back of the phone.
Using a push pin, pull out the plug on the back, located under the antenna.
Flip open the phone, exposing the keypad.
Use the opening tool to push the buttons from the bottom to lift the rubber keypad up.
Pull the keypad out of the phone.
Ein weiterer Nutzer hat diese Anleitung absolviert.
