Zum Hauptinhalt wechseln
Sanyo SCP-8100 Keypad Replacement
Was du brauchst
  1. Sanyo SCP-8100 Keypad Replacement, Battery: Schritt 1, Bild 1 von 3 Sanyo SCP-8100 Keypad Replacement, Battery: Schritt 1, Bild 2 von 3 Sanyo SCP-8100 Keypad Replacement, Battery: Schritt 1, Bild 3 von 3
    • Push and hold the button on the back toward the direction of the arrow to unlock the battery.
    • Lift and remove the battery from the back of the phone.
  2. Sanyo SCP-8100 Keypad Replacement, Back Panel: Schritt 2, Bild 1 von 2 Sanyo SCP-8100 Keypad Replacement, Back Panel: Schritt 2, Bild 2 von 2
    • Using a push pin, pull out the plug on the back, located under the antenna.
    • You may try to use a spudger or opening tool, however, you may damage the plug because those tools are too thick.
  3. Sanyo SCP-8100 Keypad Replacement: Schritt 3, Bild 1 von 1
    • Unscrew the four 6mm long screws with a Tri-Wing Y1 screwdriver.
  4. Sanyo SCP-8100 Keypad Replacement: Schritt 4, Bild 1 von 2 Sanyo SCP-8100 Keypad Replacement: Schritt 4, Bild 2 von 2
    • Use a plastic opening tool to pry the back panel along the edges.
    • You may need to apply some force when prying.
  5. Sanyo SCP-8100 Keypad Replacement: Schritt 5, Bild 1 von 3 Sanyo SCP-8100 Keypad Replacement: Schritt 5, Bild 2 von 3 Sanyo SCP-8100 Keypad Replacement: Schritt 5, Bild 3 von 3
    • While removing the back panel, take out the rubber cover on each side.
  6. Sanyo SCP-8100 Keypad Replacement, Keypad: Schritt 6, Bild 1 von 2 Sanyo SCP-8100 Keypad Replacement, Keypad: Schritt 6, Bild 2 von 2
    • Pull the volume and camera buttons off from the side of the phone.
  7. Sanyo SCP-8100 Keypad Replacement: Schritt 7, Bild 1 von 2 Sanyo SCP-8100 Keypad Replacement: Schritt 7, Bild 2 von 2
    • Pull the gray frame covering the charging port from the bottom of the phone.
  8. Sanyo SCP-8100 Keypad Replacement: Schritt 8, Bild 1 von 2 Sanyo SCP-8100 Keypad Replacement: Schritt 8, Bild 2 von 2
    • Use the opening tool to lift the motherboard up from the phone.
    • Be careful and pry the motherboard off slowly. The motherboard will be attached to the phone at the top by a metal ribbon.
  9. Sanyo SCP-8100 Keypad Replacement: Schritt 9, Bild 1 von 3 Sanyo SCP-8100 Keypad Replacement: Schritt 9, Bild 2 von 3 Sanyo SCP-8100 Keypad Replacement: Schritt 9, Bild 3 von 3
    • Flip open the phone, exposing the keypad.
    • Use the opening tool to push the buttons from the bottom to lift the rubber keypad up.
    • Pull the keypad out of the phone.
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
Irenz Afable
57 Reputation
3 Anleitungen geschrieben
Cal Poly, Team 10-41, Amido Spring 2013 Mitglied von Cal Poly, Team 10-41, Amido Spring 2013
CPSU-AMIDO-S13S10G41
4 Mitglieder
12 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 4
Insgesamt: 384
