Einleitung
In order to install the speaker for the Sanyo SCP-8100, you will need to unscrew and pry the back panel off of the phone. The speaker is located on the back panel itself and easy to replace.
- Note: In order to pull out the plug on the back of the phone that is hiding one of the screw, you will need to use a push pin. A spudger or opening tool is too thick to take it out.
Was du brauchst
Push and hold the button on the back toward the direction of the arrow to unlock the battery.
Lift and remove the battery from the back of the phone.
Using a push pin, pull out the plug on the back, located under the antenna.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
