Zum Hauptinhalt wechseln
Sanyo VPC S1275 Case Replacement
Was du brauchst
  1. Sanyo VPC S1275 Case Replacement, Battery: Schritt 1, Bild 1 von 1
    • Place your thumb on the right side of the camera over the battery door.
    • Slide the battery door to the right until the door lifts up.
  2. Sanyo VPC S1275 Case Replacement: Schritt 2, Bild 1 von 1
    • Remove and recycle old batteries.
  3. Sanyo VPC S1275 Case Replacement, Case: Schritt 3, Bild 1 von 3 Sanyo VPC S1275 Case Replacement, Case: Schritt 3, Bild 2 von 3 Sanyo VPC S1275 Case Replacement, Case: Schritt 3, Bild 3 von 3
    • Remove the following six screws using the Phillips #00 screwdriver:
    • Two screws on the left side of the camera.
    • Two screws on the right side of the camera.
    • Two screws on the bottom of the camera.
  4. Sanyo VPC S1275 Case Replacement: Schritt 4, Bild 1 von 2 Sanyo VPC S1275 Case Replacement: Schritt 4, Bild 2 von 2
    • Open the battery slot on the bottom of the camera by sliding the door to the right.
    • Remove the single 4 mm screw on the bottom right using the Phillips #00 screwdriver.
  5. Sanyo VPC S1275 Case Replacement: Schritt 5, Bild 1 von 3 Sanyo VPC S1275 Case Replacement: Schritt 5, Bild 2 von 3 Sanyo VPC S1275 Case Replacement: Schritt 5, Bild 3 von 3
    • Insert a spudger in the seam at the bottom of the camera.
    • Gently separate the rear case from the front of the camera.
  6. Sanyo VPC S1275 Case Replacement: Schritt 6, Bild 1 von 1
    • This step is only needed for the case and logic board replacement
    • Using the Phillips #00 screwdriver, remove the single screw attached to the front casing in the top left corner. The front case should easily separate.
  7. Sanyo VPC S1275 Case Replacement: Schritt 7, Bild 1 von 1
    • This step is only needed for the case replacement.
    • Using the Phillips #00 screwdriver, remove the screw on the inside of the battery door.
    • Slide the battery door off of the hinge.
Abschluss
Cal Poly, Team 24-24, Regan Spring 2010 Mitglied von Cal Poly, Team 24-24, Regan Spring 2010
CPSU-REGAN-S10S24G24
4 Mitglieder
12 Anleitungen geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 8
Insgesamt: 2,160
