Was du brauchst
Cameras powers on and the broken LCD becomes immediately evident.
Remove the battery
Remove the camera strap
Remove the four screws on the right side of the camera
Remove the two screws on the left side.
remove the four screws on the bottom of the camera.
The two screws on the thread for a tripod are longer than the others, keep those separated.
Here is a look at the screws from the camera. The two screws from the tripod thread are the longest.
Start splitting the housing with either an opening tool or your fingernails. The housing does not require a lot of force and will easily unsnap.
The front cover seems to be easiest and will come off first
Open the ribbon cable connector by pulling the white clasp gently up.
Remove the old LCD.
Here is the new LCD. Note the protective cover. Remove that cover by pulling on the green tab after installing the LCD to the PCB.
After reassembling your camera, hopefully it will look like this.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
