Einleitung
Steps on how to remove the lens. Removal of the LCD display and the outside case is required.
Werkzeuge
Ersatzteile
Keine Ersatzteile angegeben.
Turn the camera off by pressing the small, square button embedded in the top rim of the camera.
Slide out and open the hatch located on the bottom-right side of the camera.
In the revealed compartment, move the small notch and push in on the battery to remove it.
Using the Phillips #00 Screwdriver, remove the 8 screws located around the sides and bottom of the camera.
Using the spudger, slowly pry the rear panel away from the left side.
Using the Phillips #00 Screwdriver, remove the 8 black screws connecting the green keypad chip to the rear panel.
Using the Phillips #00 Screwdriver, remove the 3 screws located across the top of the camera.
Using the spudger, gently pry the front cover of the camera off.
The yellow ribbon is attached to the right side of the screen and goes to a black connector piece.
Gently flip the black connector away from the LCD screen to unlock the yellow ribbon.
Carefully pull the yellow ribbon towards the LCD screen to disconnect it.
The LCD screen should now be disconnected from the rest of the camera and a pry tool can be used to lift it out of its casing.
Using the Phillips #00 Screwdriver, remove the two screws holding the lens in place.
While keeping hold of the lens, flip the entire assembly around.
Using your fingers, gently push the lens out from its position in the casing.
Carefully unplug the golden wire from the motherboard to remove the lens from the assembly.
Ein weiterer Nutzer hat diese Anleitung absolviert.
