Was du brauchst
Make sure the camera is powered off by pressing and holding the small, square button embedded in the top rim of the camera.
Locate the hatch found on the bottom of the camera.
Open the hatch by gripping the small notch and sliding it outwards.
Using your Phillips #000 Screwdriver, remove the eight screws located around the sides and bottom of the camera.
Orient the camera so the display is facing up.
Gently pull off the rear panel surrounding the display.
Remove the eight black screws connecting the keypad circuit board to the rear panel.
With a plastic opening tool, gently remove the chrome framing on the left and right sides of the camera.
Flip the camera over so the lens is facing up.
Gently lift up the front panel to remove it from the rest of the camera.
Gently remove the loosened chrome frame and connected shutter button from the camera.
