Zum Hauptinhalt wechseln
Sanyo VPC-X1200 flash replacement
Was du brauchst
  1. Sanyo VPC-X1200 flash replacement, Back Case: Schritt 1, Bild 1 von 3 Sanyo VPC-X1200 flash replacement, Back Case: Schritt 1, Bild 2 von 3 Sanyo VPC-X1200 flash replacement, Back Case: Schritt 1, Bild 3 von 3
    • Remove the five case screws with a Phillips #00 Screwdriver.
    • Five 3.5mm Phillips Screws
  2. Sanyo VPC-X1200 flash replacement: Schritt 2, Bild 1 von 1
    • Gently lift up the back cover and set aside.
  3. Sanyo VPC-X1200 flash replacement, LCD Screen: Schritt 3, Bild 1 von 2 Sanyo VPC-X1200 flash replacement, LCD Screen: Schritt 3, Bild 2 von 2
    • Gently lift up on the left side of the LCD and slowly pull it to the left side of the camera but do not remove entirely, there is a ribbon connector.
    • Be careful not to rip out the ribbon connector.
  4. Sanyo VPC-X1200 flash replacement: Schritt 4, Bild 1 von 2 Sanyo VPC-X1200 flash replacement: Schritt 4, Bild 2 von 2
    • To clear the ribbon connection underneath the screen, lift up the black ribbon gate with the spudger.
    • Gently lift ribbon out of the gate and set screen aside.
  5. Sanyo VPC-X1200 flash replacement, Button Plate: Schritt 5, Bild 1 von 2 Sanyo VPC-X1200 flash replacement, Button Plate: Schritt 5, Bild 2 von 2
    • There are five screws of three different sizes which need removal.
    • One 4.5mm screw
    • Four 3.5mm screws, one on the button side
    • One 5.5mm screws
  6. Sanyo VPC-X1200 flash replacement: Schritt 6, Bild 1 von 2 Sanyo VPC-X1200 flash replacement: Schritt 6, Bild 2 von 2
    • Slowly lift metal tray to the right.
    • Be careful not to bend the screw tabs or rip out the ribbon cable.
    • Remove ribbon cable by using the spudger to lift up the black ribbon gate to release the ribbon
  7. Sanyo VPC-X1200 flash replacement, Lens Unit: Schritt 7, Bild 1 von 1
    • Disconnect the two ribbon cables from the lens unit by using the spudger to lift the ribbon gates.
    • One gate is black and another is white.
  8. Sanyo VPC-X1200 flash replacement: Schritt 8, Bild 1 von 2 Sanyo VPC-X1200 flash replacement: Schritt 8, Bild 2 von 2
    • Remove the three silver screws.
    • Three 5.5mm screws
  9. Sanyo VPC-X1200 flash replacement: Schritt 9, Bild 1 von 1
    • Lift the lens unit free of the camera. A spudger can be used to separate the lens unit if necessary.
  10. Sanyo VPC-X1200 flash replacement, Flash Lens: Schritt 10, Bild 1 von 3 Sanyo VPC-X1200 flash replacement, Flash Lens: Schritt 10, Bild 2 von 3 Sanyo VPC-X1200 flash replacement, Flash Lens: Schritt 10, Bild 3 von 3
    • Remove 4 screws attached to the exterior silver bezel.
    • Four 3.5mm screws
  11. Sanyo VPC-X1200 flash replacement: Schritt 11, Bild 1 von 1
    • Remove round silver bezel from the front of the camera.
  12. Sanyo VPC-X1200 flash replacement: Schritt 12, Bild 1 von 1
    • Remove the two screws on the bottom of the front cover.
  13. Sanyo VPC-X1200 flash replacement: Schritt 13, Bild 1 von 1
    • Remove tripod mount.
  14. Sanyo VPC-X1200 flash replacement: Schritt 14, Bild 1 von 1
    • Carefully lift off the front cover plate of the camera.
  15. Sanyo VPC-X1200 flash replacement: Schritt 15, Bild 1 von 1
    • Remove the flash lens using the spudger or a finger.
    • It will be attached by a piece of tape, peel the lens off of that piece of tape without removing the tape.
Abschluss
Cal Poly, Team 7-10, Maness Spring 2010 Mitglied von Cal Poly, Team 7-10, Maness Spring 2010
CPSU-MANESS-S10S7G10
4 Mitglieder
14 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 7
Insgesamt: 2,137
