Zum Hauptinhalt wechseln
Ersatzteile
Keine Ersatzteile angegeben.
  1. Use a push pin or tweezers to remove the neoprene screw-cover located on the upper, left corner of the back casing.
    • Use a push pin or tweezers to remove the neoprene screw-cover located on the upper, left corner of the back casing.
  2. MacBook Akku Fix Kits
    Ab $69.99
    Buy Now
    Ab $69.99
    Buy Now
  3. Unscrew all four, 5mm Tri-Wing screws.
    • Unscrew all four, 5mm Tri-Wing screws.
  4. Pry the back casing off the device using a spudger.  Work your way along the edges to completely separate the back casing from the device. This step may require extra force. But too much force could break the back casing.
    • Pry the back casing off the device using a spudger. Work your way along the edges to completely separate the back casing from the device.
    • This step may require extra force. But too much force could break the back casing.
    • Remove the headphone jack cover when separating the back casing. The headphone jack is located on the opposite side of the antenna.
Abschluss
Cassandra Stavros
27 Reputation
2 Anleitungen geschrieben
USF Tampa, Team 1-6, Leahy Fall 2014 Mitglied von USF Tampa, Team 1-6, Leahy Fall 2014
USFT-LEAHY-F14S1G6
6 Mitglieder
10 Anleitungen geschrieben
Kommentar hinzufügen
Statistik anzeigen:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 36
