Zum Hauptinhalt wechseln
Sanyo-PM 8200 Motherboard Replacement
Was du brauchst
  1. Sanyo-PM 8200 Motherboard Replacement, Power Off Phone: Schritt 1, Bild 1 von 1
    • Power down the phone by holding down the red "end" button.
  2. Sanyo-PM 8200 Motherboard Replacement, Remove Old Battery: Schritt 2, Bild 1 von 1
    • Push and hold the button on the back toward the direction of the arrow to unlock the battery.
    • Lift and remove the battery from the back of the phone.
  3. Sanyo-PM 8200 Motherboard Replacement, Back Casing: Schritt 3, Bild 1 von 1
    In diesem Schritt verwendetes Werkzeug:
    Kaufen
    • Use a push pin or tweezers to remove the neoprene screw-cover located on the upper, left corner of the back casing.
  4. Sanyo-PM 8200 Motherboard Replacement: Schritt 4, Bild 1 von 1
    • Unscrew all four, 5mm Tri-Wing screws.
  5. Sanyo-PM 8200 Motherboard Replacement: Schritt 5, Bild 1 von 2 Sanyo-PM 8200 Motherboard Replacement: Schritt 5, Bild 2 von 2
    • Pry the back casing off the device using a spudger. Work your way along the edges to completely separate the back casing from the device.
    • This step may require extra force. But too much force could break the back casing.
    • Remove the headphone jack cover when separating the back casing. The headphone jack is located on the opposite side of the antenna.
  6. Sanyo-PM 8200 Motherboard Replacement, Lift the Motherboard: Schritt 6, Bild 1 von 1
    • Gently lift up the motherboard. The keypad should now be exposed.
  7. Sanyo-PM 8200 Motherboard Replacement, Disconnect the Flex Ribbon: Schritt 7, Bild 1 von 1
    Kaufen
    • Using tweezers, pull on the silver flex ribbon to disconnect it from the motherboard.
  8. Sanyo-PM 8200 Motherboard Replacement, Remove the Motherboard: Schritt 8, Bild 1 von 1
    • Remove the motherboard from the back of the phone.
Abschluss
Michaella
101 Reputation
1 Anleitung geschrieben
USF Tampa, Team 1-6, Leahy Fall 2014 Mitglied von USF Tampa, Team 1-6, Leahy Fall 2014
USFT-LEAHY-F14S1G6
6 Mitglieder
10 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 7
Insgesamt: 385
