Was du brauchst
Push and hold the button on the back toward the direction of the arrow to unlock the battery.
Lift and remove the battery from the back of the phone.
Use a push pin or tweezers to remove the neoprene screw-cover located on the upper, left corner of the back casing.
Pry the back casing off the device using a spudger. Work your way along the edges to completely separate the back casing from the device.
Remove the headphone jack cover when separating the back casing. The headphone jack is located on the opposite side of the antenna.
Gently lift up the motherboard. The keypad should now be exposed.
Using tweezers, pull on the silver flex ribbon to disconnect it from the motherboard.
