Einleitung
When your light bulb wears out and your Scentsy warmer doesn’t melt the wax as well as they are supposed to, then it’s time to replace the light bulb. It depends on the warmer that you have, different Scentsy warmers take light bulbs with different wattage. Using a light bulb with a lower wattage can result in the wax not being melted all the way. Using a light bulb with a higher wattage can be dangerous and potentially damage your warmer. Therefore, I recommend you use a light bulb with the correct wattage.
Was du brauchst
Unplug the device's power cord from the electrical outlet.
Carefully unscrew the light bulb from its socket in a counterclockwise direction.
Remove the light bulb from the device.
Add in a few cubes of wax.
Turn the device on.
Make sure the device is powering on by observing the light indication.
Once complete, the warmer should turn on and melt the wax completely, creating a good fragrance in your household.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
