Zum Hauptinhalt wechseln
Sceptre X9 Komodo VII Board Cover Replacement
Was du brauchst
  1. Sceptre X9 Komodo VII Board Cover Replacement, Stand: Schritt 1, Bild 1 von 1
    • Place the monitor face down.
    • Remove the four 11.5mm screws with a #2 Phillips screwdriver.
    • Remove the stand by pulling it out.
  2. Sceptre X9 Komodo VII Board Cover Replacement: Schritt 2, Bild 1 von 1
    • Remove two 11.5mm screws with a #2 Phillips screwdriver.
    • Remove the plastic bar.
  3. Sceptre X9 Komodo VII Board Cover Replacement, Board Cover: Schritt 3, Bild 1 von 1
    • Using a #2 Phillips screwdriver, remove the six 7mm screws at the circled locations.
  4. Sceptre X9 Komodo VII Board Cover Replacement: Schritt 4, Bild 1 von 3 Sceptre X9 Komodo VII Board Cover Replacement: Schritt 4, Bild 2 von 3 Sceptre X9 Komodo VII Board Cover Replacement: Schritt 4, Bild 3 von 3
    • Pry the monitor using the plastic opening tool to release the clips holding the cover on.
    • There are four clips on each side, four on the top, and one on the bottom.
    • You may hear a loud snapping noise when releasing the clips. Do not be alarmed, it is natural.
    • Once all the clips have been released, remove the cover by pulling it up.
  5. Sceptre X9 Komodo VII Board Cover Replacement: Schritt 5, Bild 1 von 2 Sceptre X9 Komodo VII Board Cover Replacement: Schritt 5, Bild 2 von 2
    • Using the #2 Phillips screwdriver, remove the one 6mm screw.
    • Unplug the indicated cable by pulling on the base.
    • Slide the cover toward the top of the monitor.
    • Remove the cover.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Ted Hsueh
170 Reputation
3 Anleitungen geschrieben
Cal Poly, Team 16-56, Forte Fall 2012 Mitglied von Cal Poly, Team 16-56, Forte Fall 2012
CPSU-FORTE-F12S16G56
5 Mitglieder
13 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 5
Letzte 30 Tage: 15
Insgesamt: 470
