Was du brauchst
Place the monitor face down.
Remove the four 11.5mm screws with a #2 Phillips screwdriver.
Remove the stand by pulling it out.
Remove two 11.5mm screws with a #2 Phillips screwdriver.
Remove the plastic bar.
Using a #2 Phillips screwdriver, remove the six 7mm screws at the circled locations.
Pry the monitor using the plastic opening tool to release the clips holding the cover on.
Once all the clips have been released, remove the cover by pulling it up.
Using the #2 Phillips screwdriver, remove the one 6mm screw.
Unplug the indicated cable by pulling on the base.
Slide the cover toward the top of the monitor.
Remove the cover.
Disconnect the two connectors at the top-left of the power board.
Disconnect the two connectors at the very bottom of the power board (pink wire).
Disconnect the multi-pin connector at the top of the motherboard.
Use a #2 Phillips to unscrew the two 4.5mm screws on each side of the back panel.
Carefully side the connectors through their respective openings.
Lif the back panel to reveal the LCD back cover.
Use a #2 Phillips to remove the four 6mm screws on the bezel for each side of the back cover.
Remove the bezels from the LCD back cover (the bezels should simply fall off once the screws are removed).
Use a #0 Phillips to remove the three 4.5mm screws located on the LCD back cover.
Lift the inner panel to remove it.
Disconnect the muti-pin connector on the LCD back cover by firmly pulling down on it.
Use a #0 Phillips to remove the two 6mm screws on each side of the LCD cover.
There are tabs holding down the cover. You may have to use a bit of force to pry them open.
A small flat-blade screwdriver can be used to pry off LCD cover.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
