Einleitung
I repaired a couple of screen replacements for the Samsung Note 20
I did one that needed a back glass and one that did not.
Created a custom back glass to troll my older brother for not having a case on a brand new phone. The replacement screens had not even been created yet until now we waited for 3 weeks!
Werkzeuge
Ersatzteile
Keine Ersatzteile angegeben.
Einführungsvideo
On this Note 20 the OLED is clearly broken and has a crack on the side.
The back has no damage to it so apply heat.
Start from the buttom straight up and down push tool in until you hit the frame you while hear a sound
Slide tool at angle stop at the curve
After loosening the buttom pull tool out.
Now pry with your fingers and pull up with suction cup.
While sticking splicer on curved edge side slowly working wiggling down the curve edge
Lift and wiggle the back glass off
Remove 6 PH000 Screws from the wireless charging pad covering the battery connection.
Disconnect wireless coil from connections with plastic spudger
Use spudger at top on the metal squeezing it under the top of the wireless charging pad bracket.
Lift and wiggle slowly the charging pad off while locating the battery connection
Battery Connection!!
Remove 4 PH000 Screws to the ear speaker bracket.
Also disconnect this connection!
Make sure its disconnected
Disconnect all yellow boxed connections!
Remove the 2 PH000 Screws holding the camera
Lift mainboard with spudger from ear speaker goin down using the frame as a leveler
Front Camera Location
Use straight edge blade at bottom of camera to break it loose. You can actually pull the glue/adhesive out it will come out in one chunk.
Lift camera out slowly
Remove 5 PH000 Screws for the Loudspeaker bracket
Use spudger to lift out bracket
Disconnect flex cables
Remove 3 Black PH000 Screws to microphoned board and charger port
Lift out Microphone board 1st
Then lift out charge port wiggling it loose
Good lift spot with point end of spudger at arrow location
Loosen Adhesive
Remove 2 black PH000 Screws on top right lifting flex out.
Remove 2 PH000 Screws on Bottom right lift flex out.
Spray with alcohol start a little pry to get alcohol under battery
Lift with suction cup on battery
Bam its out not damaged
Vibator
Frame Flex Cables
Charge Port goes in 1st
Then microphone board goes on top of charge port. Connect the flex cables
Lay the main board down in new frame
Insert the front camera after laying the board down
Lay out adhesive for under the battery
Disconnect battery
Connect al loose flex cables to there connections
Apply adhesive to back of phone lay back glass back down
If you have to replace back glass you have to move microphone from old back glass rear camera lens to the new back glass.
I use liquid adhesive to hold the back glass down
Clamp the back down for a couple hours
During this repair on the black Note 20 Ultra I noticed the screen looked refurbished had issues with screws being stripped I did some serious work drilling into the phone. Which is not included in this guide.
Before I worked on the phone that had the stripping screw issue I already had worked on the phone which I made a video and had not issues with screws stripping the phone I did the picture guide was clearly refurbished straight talk phone.
2 weitere Nutzer haben diese Anleitung absolviert.
