Zum Hauptinhalt wechseln
Sears Craftsman 315.109020 Blade/ Blade Cover Replacement
Was du brauchst
  1. Sears Craftsman 315.109020 Blade/ Blade Cover Replacement, Blade/ Blade Cover: Schritt 1, Bild 1 von 2 Sears Craftsman 315.109020 Blade/ Blade Cover Replacement, Blade/ Blade Cover: Schritt 1, Bild 2 von 2
    • Although this is not a difficult fix, it can definitely make a mess.
    • Lay down a dirty towel or work rag and place the saw on top of the towel.
    • Handle the saw with care and avoid placing your hands on or near the blade when possible.
  2. Sears Craftsman 315.109020 Blade/ Blade Cover Replacement: Schritt 2, Bild 1 von 3 Sears Craftsman 315.109020 Blade/ Blade Cover Replacement: Schritt 2, Bild 2 von 3 Sears Craftsman 315.109020 Blade/ Blade Cover Replacement: Schritt 2, Bild 3 von 3
    • Use the crescent wrench to remove the hex washer head screw and the washer.
    • Gently lift the blade up and pull it off of the internal threaded shaft.
    • If the hex washer head screw, or the entire blade spins as you turn the wrench, a quick jerk of the crescent wrench should loosen the screw.
    • Although many screws loosen in the clockwise direction, the hex washer head screw on this circular saw loosens in the counter-clockwise direction.
  3. Sears Craftsman 315.109020 Blade/ Blade Cover Replacement: Schritt 3, Bild 1 von 2 Sears Craftsman 315.109020 Blade/ Blade Cover Replacement: Schritt 3, Bild 2 von 2
    • Lift up on the blade cover until it unsnaps from the washer.
    • The blade cover will come off easier if the bulk of the cover is facing away from the saw.
Abschluss
Cal Poly, Team 17-4, Green Fall 2015 Mitglied von Cal Poly, Team 17-4, Green Fall 2015
CPSU-GREEN-F15S17G4
3 Mitglieder
5 Anleitungen geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 11
Letzte 30 Tage: 44
Insgesamt: 1,623
