Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Store
Ersatzteile
Keine Ersatzteile angegeben.
  1. Using a Phillips head screwdriver remove  six screws from the bottom of the console. The six screws are marked.
    • Using a Phillips head screwdriver remove six screws from the bottom of the console.
    • The six screws are marked.
  2. Remove the two screws that attach the Genesis' connector to the rest of the console.
    • Remove the two screws that attach the Genesis' connector to the rest of the console.
    • The two screws are marked in the diagram.
  3. Slide the lock tab to the left to separate the halves of the console.
    • Slide the lock tab to the left to separate the halves of the console.
  4. Lift from the left side to remove the top of the case.
    • Lift from the left side to remove the top of the case.
  5. Using the spudger, pry the cover off of the Genesis attachment.
    • Using the spudger, pry the cover off of the Genesis attachment.
  6. Lift the top of the case to remove the cover.
    • Lift the top of the case to remove the cover.
  7. Remove the faceplate by pulling it up, then out.
    • Remove the faceplate by pulling it up, then out.
  8. Remove metal plate by unscrewing the three screws with the Phillips head screwdriver and then lifting the plate. The three screws are shown on the diagram.
    • Remove metal plate by unscrewing the three screws with the Phillips head screwdriver and then lifting the plate.
    • The three screws are shown on the diagram.
  9. Remove the two screws from the plastic bar. The two screws are shown pictured.
    • Remove the two screws from the plastic bar.
    • The two screws are shown pictured.
  10. To remove the CD tray Remove the four screws with the Phillips head screwdriver.
    • To remove the CD tray
    • Remove the four screws with the Phillips head screwdriver.
  11. Carefully unplug the wire connected to optical reader.
    • Carefully unplug the wire connected to optical reader.
  12. Remove the four screws on the underside of the CD tray with a small Phillips head screwdriver. The four screws are highlighted on the diagram.
    • Remove the four screws on the underside of the CD tray with a small Phillips head screwdriver.
    • The four screws are highlighted on the diagram.
    • The four springs below the circuit board are attached to the screws, so be careful not to lose them when you remove the screws.
  13. Carefully remove the CD tray from circuit board.
    • Carefully remove the CD tray from circuit board.
Abschluss
Ein weiterer Nutzer hat diese Anleitung absolviert.
sskyllin
21 Reputation
2 Anleitungen geschrieben
Cal Poly, Team 5-14, Maness Fall 2010 Mitglied von Cal Poly, Team 5-14, Maness Fall 2010
CPSU-MANESS-F10S5G14
4 Mitglieder
12 Anleitungen geschrieben
Kommentar hinzufügen
Statistik anzeigen:
Letzten 24 Stunden: 0
Letzten 7 Tage: 4
Letzten 30 Tage: 20
Insgesamt: 8,021
