Was du brauchst
Using a Phillips head screwdriver remove six screws from the bottom of the console.
The six screws are marked.
Remove the two screws that attach the Genesis' connector to the rest of the console.
The two screws are marked in the diagram.
Remove metal plate by unscrewing the three screws with the Phillips head screwdriver and then lifting the plate.
The three screws are shown on the diagram.
To remove the CD tray
Remove the four screws with the Phillips head screwdriver.
Remove the four screws on the underside of the CD tray with a small Phillips head screwdriver.
The four screws are highlighted on the diagram.
Eine weitere Person hat diese Anleitung absolviert.
