Zum Hauptinhalt wechseln
Einleitung
The purpose of this replacement guide is to remove the Sega plastic casing to expose the internal content for further repair.
Ersatzteile
Keine Ersatzteile angegeben.
  1. Using a Phillips head screwdriver remove  six screws from the bottom of the console. The six screws are marked.
    • Using a Phillips head screwdriver remove six screws from the bottom of the console.
    • The six screws are marked.
  2. Remove the two screws that attach the Genesis' connector to the rest of the console.
    • Remove the two screws that attach the Genesis' connector to the rest of the console.
    • The two screws are marked in the diagram.
  3. Slide the lock tab to the left to separate the halves of the console.
    • Slide the lock tab to the left to separate the halves of the console.
  4. Lift from the left side to remove the top of the case.
    • Lift from the left side to remove the top of the case.
  5. Using the spudger, pry the cover off of the Genesis attachment.
    • Using the spudger, pry the cover off of the Genesis attachment.
  6. Lift the top of the case to remove the cover.
    • Lift the top of the case to remove the cover.
  7. Remove the faceplate by pulling it up, then out.
    • Remove the faceplate by pulling it up, then out.
Abschluss
To reassemble the device, follow these instructions in reverse order.
Ein weiterer Nutzer hat diese Anleitung absolviert.
Ryan Kotzebue
259 Reputation
4 Anleitungen geschrieben
Cal Poly, Team 5-14, Maness Fall 2010 Mitglied von Cal Poly, Team 5-14, Maness Fall 2010
CPSU-MANESS-F10S5G14
4 Mitglieder
12 Anleitungen geschrieben
Kommentar hinzufügen
Statistik anzeigen:
Letzten 24 Stunden: 0
Letzten 7 Tage: 0
Letzten 30 Tage: 10
Insgesamt: 4,569
