Zum Hauptinhalt wechseln
Sega Dreamcast Fan Replacement
Was du brauchst
  1. Sega Dreamcast Fan Replacement, Expansion Bay: Schritt 1, Bild 1 von 2 Sega Dreamcast Fan Replacement, Expansion Bay: Schritt 1, Bild 2 von 2
    • Verify that the console is disconnected from the AC outlet before you begin.
    • Flip the console over on its back.
    • Take note of your model number, in case replacement parts are needed.
  2. Sega Dreamcast Fan Replacement: Schritt 2, Bild 1 von 3 Sega Dreamcast Fan Replacement: Schritt 2, Bild 2 von 3 Sega Dreamcast Fan Replacement: Schritt 2, Bild 3 von 3
    • Remove the expansion bay by applying pressure to the small clip on the expansion bay while prying it away from the console.
  3. Sega Dreamcast Fan Replacement, Top Cover: Schritt 3, Bild 1 von 1
    • Locate and remove all four black 12mm Phillips #02 screws from the underside of the console.
    • Note: Remove the expansion bay to locate the fourth screw
  4. Sega Dreamcast Fan Replacement: Schritt 4, Bild 1 von 1
    • Internal components can be loose. Be careful that they do not fall out when removing the cover.
    • Turn the console right side up.
    • Remove the top cover by gently lifting the upper portion of the console.
  5. Sega Dreamcast Fan Replacement, Fan: Schritt 5, Bild 1 von 1
    • Remove the white fan header by gently pulling it away from from the controller port.
    • The white fan header may already be detached if you have completed the Controller Port Disassembly Guide.
  6. Sega Dreamcast Fan Replacement: Schritt 6, Bild 1 von 1
    • Remove the two 8.5mm Philips #00 screws from the fan bracket.
  7. Sega Dreamcast Fan Replacement: Schritt 7, Bild 1 von 2 Sega Dreamcast Fan Replacement: Schritt 7, Bild 2 von 2
    • Remove the two 17.5mm Philips #00 screws from the fan bracket.
    • Remove the fan from the bracket.
  8. Sega Dreamcast Fan Replacement, Fan: Schritt 8, Bild 1 von 2 Sega Dreamcast Fan Replacement, Fan: Schritt 8, Bild 2 von 2
    • Connect the new fan to the fan bracket using two 17.5mm Philips #00 screws.
    • Replace the fan bracket in the Dreamcast using two 8.5mm Philips #00 screws.
Abschluss
5 weitere Personen haben diese Anleitung absolviert.
Thorr686
500 Reputation
2 Anleitungen geschrieben
Cal Poly, Team 5-1, Regan Fall 2009 Mitglied von Cal Poly, Team 5-1, Regan Fall 2009
CPSU-REGAN-F09S5G1
5 Mitglieder
21 Anleitungen geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 5
Letzte 30 Tage: 48
Insgesamt: 19,404
