Einleitung
A guide to remove the GD-ROM from the Sega Dreamcast.
Problem with this guide: The photos incorrectly show the power supply has been removed.
Werkzeuge
Ersatzteile
Kein Ersatzteil erforderlich.
Flip the console over on its back.
Take note of your model number, in case replacement parts are needed.
Remove the expansion bay by applying pressure to the small clip on the expansion bay while prying it away from the console.
Locate and remove all four black 12mm Phillips #02 screws from the underside of the console.
Turn the console right side up.
Remove the top cover by gently lifting the upper portion of the console.
Detach the orange cable by giving it a gentle pull while wiggling the cable back and forth until it loosens from the logic board.
Detach the cables by gently pulling the three GD-ROM cables to remove them from the logic board.
Remove the two black 12mm Philips #02 screws located on the left side of the GD-ROM bracket.
Remove the GD-ROM by gently lifting it from its base.
7 weitere Nutzer haben diese Anleitung absolviert.
