Zum Hauptinhalt wechseln
Sega Game Gear Headphone Jack/Volume Wheel Replacement
Was du brauchst
  1. Sega Game Gear Headphone Jack/Volume Wheel Replacement, Battery: Schritt 1, Bild 1 von 1
    • Place your device upside down and locate the two battery compartments.
  2. Sega Game Gear Headphone Jack/Volume Wheel Replacement: Schritt 2, Bild 1 von 1
    • Press on the tabs at the bottom of the battery covers then lift up to remove.
    • Remove batteries if they are present.
  3. Sega Game Gear Headphone Jack/Volume Wheel Replacement, Case: Schritt 3, Bild 1 von 1
    • Remove the following screws:
    • Six Phillips screws
    • One 4.5 mm Gamebit screw
  4. Sega Game Gear Headphone Jack/Volume Wheel Replacement: Schritt 4, Bild 1 von 1
    • Use tweezers to take all other screws out.
  5. Sega Game Gear Headphone Jack/Volume Wheel Replacement: Schritt 5, Bild 1 von 2 Sega Game Gear Headphone Jack/Volume Wheel Replacement: Schritt 5, Bild 2 von 2
    • Gently open the case by unfolding it over the top of the Sega Game Gear.
    • Do not pull the back of the case away, as cables are connected between both sides.
  6. Sega Game Gear Headphone Jack/Volume Wheel Replacement: Schritt 6, Bild 1 von 3 Sega Game Gear Headphone Jack/Volume Wheel Replacement: Schritt 6, Bild 2 von 3 Sega Game Gear Headphone Jack/Volume Wheel Replacement: Schritt 6, Bild 3 von 3
    • Carefully unplug the 2 white-tipped connectors on the top cover.
  7. Sega Game Gear Headphone Jack/Volume Wheel Replacement, Headphone Jack/Volume Wheel: Schritt 7, Bild 1 von 2 Sega Game Gear Headphone Jack/Volume Wheel Replacement, Headphone Jack/Volume Wheel: Schritt 7, Bild 2 von 2
    • Unscrew the screws to remove the metal covering.
  8. Sega Game Gear Headphone Jack/Volume Wheel Replacement: Schritt 8, Bild 1 von 1
    • The screws that need to be removed are missing from this picture.
    • Remove the two screws from the highlighted locations.
Abschluss
Brandon Page
179 Reputation
2 Anleitungen geschrieben
Cal Poly, Team 28-33, Regan Spring 2010 Mitglied von Cal Poly, Team 28-33, Regan Spring 2010
CPSU-REGAN-S10S28G33
5 Mitglieder
13 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 2
Letzte 30 Tage: 20
Insgesamt: 6,944
