Einleitung
This guide will help you disassemble your Sega Genesis II 6 button controller. You will need a Phillips #00 screwdriver to complete this guide.
This specific model was released in 1992/93, at the same time as the Sega Genesis II. However, it is also compatible with the Sega Genesis I
Was du brauchst
Flip the controller upside down.
Using a Phillips #00 screwdriver, remove the five screws holding the controller back cover in place.
Then remove the back cover of the controller, which gives you access to the motherboard of the controller.
Remove the motherboard from the controller body, after releasing the rubber part that holds the cable in the controller body
Remove the contact pads
Then remove the 8 plastic buttons
In order to disassemble the directional cross, it is necessary to levergentlypreferably with a plastic Spudger, under the 4 retaining tabs.
Then, push in the central hole with a fine tool (here a screwdriver), in order to undo the assembly
Follow these steps in reverse order to reassemble your device.
Eine weitere Person hat diese Anleitung absolviert.
100%
tayola hilft uns, die Welt in Ordnung zu bringen! Wie kann ich mithelfen?
Hier starten ›
