Einleitung
In this guide i'll show you how to disassemble the motherboard of the Sega Master System II
Was du brauchst
Flip the console on it's back and unscrew the 5 screws marked on this photo.
Once the console is upright, first gently pull the rear of the top up.
After the top is at an angle, gently remove it by pulling upwards.
Next step is the removal of the RF shield
There are 7 screws in total, please unscrew those.
The blue marked screw is shorten than the other 6 screws, this screw has to be put back in the exact same location during reassembly.
Now we have a complete view of the motherboard, thus coming to the last step.
For this step you only need to remove 3 remaining screws.
2 screws on the connector.
There's 1 shorter screw as previously with the RF shield. This small screw keeps the voltage regulator in place.
Om het apparaat weer te monteren, volg je deze instructies in omgekeerde volgorde.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
