Zum Hauptinhalt wechseln
Sega Master System Model 2 Disassembly
Was du brauchst
Einführungsvideo
  1. Sega Master System Model 2 Disassembly, The Case: Schritt 1, Bild 1 von 1
    • Take out the 5 screws at the bottom
  2. Sega Master System Model 2 Disassembly, RF Shield: Schritt 2, Bild 1 von 1
    • Remove the 5 screws (3 at the back and 2 on the front)
    • Remove the screw at the side (this screws is different then the other 5 so remember to put them away from the other 5 screws since they are similar)
    • This screw is for the rf shield under for the voltage regulator under this bigger rf shield, its not needed to remove that screw
  3. Sega Master System Model 2 Disassembly, Cartridge Slot: Schritt 3, Bild 1 von 1
    • Remove the 2 screws thats holding the cartridge slot down
  4. Sega Master System Model 2 Disassembly, The End: Schritt 4, Bild 1 von 1
    • Congratulations! You have opened your Sega Master System Model 2!
Abschluss
Screenshots taken from a video by Global Garage
3 weitere Nutzer:innen haben diese Anleitung absolviert.
Krisow
605 Reputation
2 Anleitungen geschrieben
3 Kommentare
This is in the wrong section.
Owen Ready - Antwort
Nope, its in the Sega Master System area.
Krisow -
Not a Master System
Chad Luciano - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 7
Letzte 30 Tage: 42
Insgesamt: 2,330
