Einleitung
If the headband pad or cushion on your Sennheiser HD 4.50 headphones are worn down or damaged, use this guide for instructions on replacing it. In order to complete this repair, you will need to buy a new headband pad to replace the defective one you are removing.
Was du brauchst
Extend the headphones by pulling the headband away from the base of the headphones.
Use a Phillips #000 screwdriver to remove the two screws on the silver piece on either edge of the headband.
After removing the screws, slide both silver pieces down.
Grasp the headband pad firmly with your pointer finger and thumb and gently pull the pad away from the headband until the pad is fully removed.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Ein Kommentar
Is there any guide on replacing the hinge that the ear cups are connected to?
