Zum Hauptinhalt wechseln
Sennheiser HD 4.50 Motherboard Replacement
Was du brauchst
  1. Sennheiser HD 4.50 Motherboard Replacement, Motherboard: Schritt 1, Bild 1 von 3 Sennheiser HD 4.50 Motherboard Replacement, Motherboard: Schritt 1, Bild 2 von 3 Sennheiser HD 4.50 Motherboard Replacement, Motherboard: Schritt 1, Bild 3 von 3
    • Locate the side designation on the headband-earpiece junction.
    • The motherboard is located on the right side.
    • Remove the right side ear pad.
    • Refer to the Ear Pad Removal guide for more guidance.
  2. Sennheiser HD 4.50 Motherboard Replacement: Schritt 2, Bild 1 von 3 Sennheiser HD 4.50 Motherboard Replacement: Schritt 2, Bild 2 von 3 Sennheiser HD 4.50 Motherboard Replacement: Schritt 2, Bild 3 von 3
    • Use the Phillips #00 screwdriver to remove the four 10 mm screws holding the ear cup cover in place.
    • Use an opening tool to pry off the cover.
  3. Sennheiser HD 4.50 Motherboard Replacement: Schritt 3, Bild 1 von 3 Sennheiser HD 4.50 Motherboard Replacement: Schritt 3, Bild 2 von 3 Sennheiser HD 4.50 Motherboard Replacement: Schritt 3, Bild 3 von 3
    • Use a Phillips #000 screwdriver to remove the four 6 mm screws holding the motherboard in place.
  4. Sennheiser HD 4.50 Motherboard Replacement: Schritt 4, Bild 1 von 1
    • Use tweezers to remove the hot glue that covers the wires
    • Using the tweezers, grasp and slowly pull away the wires from the motherboard until they disconnect.
  5. Sennheiser HD 4.50 Motherboard Replacement: Schritt 5, Bild 1 von 1
    • Use the iFixit opening tools to lift up on the motherboard.
    • While lifting up with the tool, grab and pull the motherboard with your free hand away from the button functions until it disconnects.
    • There may be some resistance in this step.
  6. Sennheiser HD 4.50 Motherboard Replacement: Schritt 6, Bild 1 von 1
    • Desolder the three wires that are on the underside of the motherboard now that it is free.
    • Remove the motherboard.
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
Grace Singley
577 Reputation
5 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 4
Letzte 7 Tage: 19
Letzte 30 Tage: 86
Insgesamt: 1,556
