Einleitung
one of the most common ways a pair of headphones brakes is the wires get flexed to much near the stereo jack and brake one of the 3-4 wires causing one or both of the speakers to "fail" you can save yourself $100+ with a dollar store patch cable and some solder
Was du brauchst
First find the place where the wire is broken inside the rubber coating you can find the spot usaly by moving the cable around while playing music to see at what spot it makes sound or doesn't for this guide i will take the most commonly broken spot, just above the jack.
cut the cable just above the broken spot (if its in the middle of the cable cut below the spot too)
cut your 3.5mm patch cable 3"-5" above the jack and strip 0.5"-1" off the cut end and expose the bare wire if
strip the wire from where you cut it .5-1 inch should work fine the couler codeing on the wire is as follows
red=left ear cup
blue= right ear cup
copper/gold= ground
the wires are clear coated so carefully use your lighter to burn the ends of the exposed wire
do the same to the patch cable if it has rubber sheleding just strip off about 0.25"
to find the right wires (color codes are different depending on the manufacturer):
take a multimeter and set it to resistance (or contanuity if you have a fancy one)
put one probe on the sleeve(the biggest part of of the 3.5 mm plug (the ground) and try each wire in turn with the other probe to find it
next repeat the process with the tip of the plug (the left channel)
the last wire (if you have 3) will be the right channel
you may have a 4th wire this is a seccond ground wire
simple enough match the proper wires together left to left, right to right, and ground to ground(s)
and give them a little twist
make sure all 3 wires are seperate from each other and put it in a media device to test the connection it works best if you can seperate the signals to test each ear cup individually
once it works properly
put the 2 cables paralel to each other and one of the wires down make sure its not touching any other exposed wire
wrap electrical tape around once
put a second wire down wrap it a second time with tape
bend one of the cables to face the other direction and the last wire down
wrap it 3-4 more times to make it sealed well or use heat shrink tubeing if you have it
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
