Einleitung
This guide is meant to help a user remove the hinges on a Sennheiser headset that may be faulty and/or worn down. This is a moderately simple guide as there are no components to be removed, just 9 screws to be removed. The only tools needed are a #000 Phillips screwdriver and a T6 Torx screwdriver.
Was du brauchst
Grab the earmuffs with one hand and hold the headphones with the other.
Remove the four 8mm screws on the ear cup using a #000 Phillips screwdriver to reveal the motherboard.
On one half of the ear cup that was previously removed, there will be located a motherboard. On the other half there will be a coupler holding the cup to the hinge and allowing it to move in a 360 degree manner. Remove this coupler by unscrewing the 10mm screw with the same #000 Phillips screwdriver.
On the leather part of the headset, four 6mm Torx screws need to be removed using a T6H Torx screwdriver.
On the other side of the 6mm torx screws, there is a nameplate that needs to be pried off using a pry tool.
The hinges must be removed from BOTH sides of the headphones for even one side to come out. They are attached together.
