Zum Hauptinhalt wechseln
Separating Rear Board
Was du brauchst
  1. Separating Rear Board, Remove Battery: Schritt 1, Bild 1 von 3 Separating Rear Board, Remove Battery: Schritt 1, Bild 2 von 3 Separating Rear Board, Remove Battery: Schritt 1, Bild 3 von 3
    • Place the controller face down.
    • Remove the battery cover.
    • Remove rechargeable battery or AA batteries.
    Frag FixBot
    Kommentar hinzufügen
  2. Separating Rear Board, Remove Trigger Buttons: Schritt 2, Bild 1 von 2 Separating Rear Board, Remove Trigger Buttons: Schritt 2, Bild 2 von 2
    • Remove L2 and R2 trigger buttons by pushing them away from the grips.
    Frag FixBot
  3. Separating Rear Board, Remove Screws: Schritt 3, Bild 1 von 2 Separating Rear Board, Remove Screws: Schritt 3, Bild 2 von 2
    In diesem Schritt verwendetes Werkzeug:
    • Use Tweezers to uncover two screws under the label in the battery compartment.
    • Use a T6 screwdriver to remove the four 7.3 mm screws securing the rear cover.
    Frag FixBot
  4. Separating Rear Board, Unclip Covers: Schritt 4, Bild 1 von 3 Separating Rear Board, Unclip Covers: Schritt 4, Bild 2 von 3 Separating Rear Board, Unclip Covers: Schritt 4, Bild 3 von 3
    • At the end of each grip, pry apart the covers.
    • Use fingernail or opening pick to undo the two top clips.
    • One clip next to L button.
    • One clip next to R button
    • Undo the final clip between the joysticks.
    Frag FixBot
  5. Separating Rear Board, Separate Covers: Schritt 5, Bild 1 von 1
    • Carefully move the rear cover away and from the front cover. Place it to the left.
    • Do not completely separate. The two halves are still attached via a white ribbon cable.
    Frag FixBot
  6. Separating Rear Board, Remove Ribbon Cable: Schritt 6, Bild 1 von 3 Separating Rear Board, Remove Ribbon Cable: Schritt 6, Bild 2 von 3 Separating Rear Board, Remove Ribbon Cable: Schritt 6, Bild 3 von 3
    • Unlock the ribbon cable by push open the black plastic tab.
    • The tab will slide about 1.5mm
    • Pull the ribbon cable out of the connector in the direction of the cable.
    Frag FixBot
  7. Separating Rear Board, Remove Caps: Schritt 7, Bild 1 von 2 Separating Rear Board, Remove Caps: Schritt 7, Bild 2 von 2
    • Grab the top and pull straight up on the joystick cap. Pulling out the caps one-by-one.
    Frag FixBot
  8. Separating Rear Board, Remove Screws: Schritt 8, Bild 1 von 3 Separating Rear Board, Remove Screws: Schritt 8, Bild 2 von 3 Separating Rear Board, Remove Screws: Schritt 8, Bild 3 von 3
    • Use a Phillips screwdriver to remove the nine 5.2 mm screws securing the rear circuit board.
    • Four around the Right stick
    • Four around the Left stick
    • One next to the Battery connector
    Frag FixBot
  9. Separating Rear Board, Separate Rear Board: Schritt 9, Bild 1 von 3 Separating Rear Board, Separate Rear Board: Schritt 9, Bild 2 von 3 Separating Rear Board, Separate Rear Board: Schritt 9, Bild 3 von 3
    • Pull the two rumble motors out of their housings.
    • Grab the analog sticks to pull out the circuit board
    Frag FixBot
Abschluss
2 weitere Personen haben diese Anleitung absolviert.
Brian W
1.800 Reputation
8 Anleitungen geschrieben
0 Kommentare zur Anleitung
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 11
Letzte 30 Tage: 29
Insgesamt: 893
