Zum Hauptinhalt wechseln
SereneLife Treadmill SLFTRD20 Belt Adjustment
Was du brauchst
  1. SereneLife Treadmill SLFTRD20 Belt Adjustment, SereneLife Treadmill SLFTRD20 Belt Adjustment: Schritt 1, Bild 1 von 2 SereneLife Treadmill SLFTRD20 Belt Adjustment, SereneLife Treadmill SLFTRD20 Belt Adjustment: Schritt 1, Bild 2 von 2
    • Turn on the main power switch.
  2. SereneLife Treadmill SLFTRD20 Belt Adjustment: Schritt 2, Bild 1 von 2 SereneLife Treadmill SLFTRD20 Belt Adjustment: Schritt 2, Bild 2 von 2
    • Begin by pressing the "Start" button on the machine.
    • Let the treadmill belt run at the lowest setting.
  3. SereneLife Treadmill SLFTRD20 Belt Adjustment: Schritt 3, Bild 1 von 2 SereneLife Treadmill SLFTRD20 Belt Adjustment: Schritt 3, Bild 2 von 2
    • In order to locate the roller adjustment bolts, try locating the rear left cover and rear right cover.
  4. SereneLife Treadmill SLFTRD20 Belt Adjustment: Schritt 4, Bild 1 von 3 SereneLife Treadmill SLFTRD20 Belt Adjustment: Schritt 4, Bild 2 von 3 SereneLife Treadmill SLFTRD20 Belt Adjustment: Schritt 4, Bild 3 von 3
    • Remove the attached rear left and right covers from the treadmill.
    • After removing the rear covers, you'll be able to see the adjustment bolts.
  5. SereneLife Treadmill SLFTRD20 Belt Adjustment: Schritt 5, Bild 1 von 2 SereneLife Treadmill SLFTRD20 Belt Adjustment: Schritt 5, Bild 2 von 2
    • Before we begin it's important to determine which side the belt is shifting towards.
    • If the belt is shifting to the right, then turn the right adjustment bolt to turn 1/4 clockwise. If the belt is shifting to the left, then turn the left adjustment bolt to turn 1/4 clockwise.
    • Place the Allen wrench in the left rear roller bolt.
    • Turn the left roller bolt adjustment to turn one-fourth clockwise.
    • Now stop and wait for the belt to begin to center itself.
    • You must wait for the belt to re-center between each adjustment to ensure that you do not overcorrect the belt.
  6. SereneLife Treadmill SLFTRD20 Belt Adjustment: Schritt 6, Bild 1 von 1
    • In order to fix the slipping belt during use, we need to turn off and unplug the Treadmill.
  7. SereneLife Treadmill SLFTRD20 Belt Adjustment: Schritt 7, Bild 1 von 3 SereneLife Treadmill SLFTRD20 Belt Adjustment: Schritt 7, Bild 2 von 3 SereneLife Treadmill SLFTRD20 Belt Adjustment: Schritt 7, Bild 3 von 3
    • Place the Allen wrench in the left roller bolt and turn it 1/4 clockwise to tighten the belt.
    • Repeat on the right side of the roller bolt in the same way.
  8. SereneLife Treadmill SLFTRD20 Belt Adjustment: Schritt 8, Bild 1 von 2 SereneLife Treadmill SLFTRD20 Belt Adjustment: Schritt 8, Bild 2 von 2
    • Attach the rear covers onto the left side and right side of the frames.
    • Turn the main power switch back on and run the treadmill at the lowest speed.
    • Run on the treadmill to determine if the belt is still slipping or not.
    • Repeat this procedure until the belt no longer slips.
Abschluss
2 weitere Personen haben diese Anleitung absolviert.
Alina Abbas
211 Reputation
1 Anleitung geschrieben
York University, Team S2-G2, Melo-Thaiss Summer 2021 Mitglied von York University, Team S2-G2, Melo-Thaiss Summer 2021
YORK-MELO-THAISS-SU21S2G2
1 Mitglied
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 9
Letzte 30 Tage: 53
Insgesamt: 2,400
