Zum Hauptinhalt wechseln
Shark Apex DuoClean Powered Lift Away AZ1002 Foam and Felt Filters Replacement
  1. Shark Apex DuoClean Powered Lift Away AZ1002 Foam and Felt Filters Replacement, Foam and Felt Filters: Schritt 1, Bild 1 von 2 Shark Apex DuoClean Powered Lift Away AZ1002 Foam and Felt Filters Replacement, Foam and Felt Filters: Schritt 1, Bild 2 von 2
    • Press the dust cup release button.
  2. Shark Apex DuoClean Powered Lift Away AZ1002 Foam and Felt Filters Replacement: Schritt 2, Bild 1 von 1
    • Use the handle to pull the dust cup away from the wand, then lift upwards to fully free the cup.
  3. Shark Apex DuoClean Powered Lift Away AZ1002 Foam and Felt Filters Replacement: Schritt 3, Bild 1 von 3 Shark Apex DuoClean Powered Lift Away AZ1002 Foam and Felt Filters Replacement: Schritt 3, Bild 2 von 3 Shark Apex DuoClean Powered Lift Away AZ1002 Foam and Felt Filters Replacement: Schritt 3, Bild 3 von 3
    • Pull the filter tab up to remove the large white foam filter and circular thin form at the bottom.
  4. Shark Apex DuoClean Powered Lift Away AZ1002 Foam and Felt Filters Replacement: Schritt 4, Bild 1 von 2 Shark Apex DuoClean Powered Lift Away AZ1002 Foam and Felt Filters Replacement: Schritt 4, Bild 2 von 2
    • Remove the white foam filter.
    • Go to a trash bin and shake both filters to remove loose dirt carefully debris.
  5. Shark Apex DuoClean Powered Lift Away AZ1002 Foam and Felt Filters Replacement: Schritt 5, Bild 1 von 2 Shark Apex DuoClean Powered Lift Away AZ1002 Foam and Felt Filters Replacement: Schritt 5, Bild 2 von 2
    • Rinse the filters thoroughly under lukewarm water until the water runs completely clear.
    • Avoid using hot water, as it can damage the filters.
  6. Shark Apex DuoClean Powered Lift Away AZ1002 Foam and Felt Filters Replacement: Schritt 6, Bild 1 von 1
    • Allow the filters to air dry completely before reinserting them in the vacuum.
    • If the filters are not left to completely dry before replacing them in the vacuum, lingering water can cause the filters to mold.
Abschluss
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 10
Insgesamt: 82
