Einleitung
Continued use of the Shark Apex DuoClean Powered Lift-Away (Model-AZ1002) can lead to loss of suction.If your vaccum is experiencing an issue with picking up debri , follow the steps of this guide to clean and/or replace the filter.
Use the handle to pull the dust cup away from the wand, then lift upwards to fully free the cup.
Pull the filter tab up to remove the large white foam filter and circular thin form at the bottom.
Remove the white foam filter.
Go to a trash bin and shake both filters to remove loose dirt carefully debris.
Rinse the filters thoroughly under lukewarm water until the water runs completely clear.
