Einleitung
Use this guide to replace the filter in your Shark Clean Sense HP102PET. Changing out your filter should be a regular chore when owning this device. Keeping the filter maintained ensures that your purifier is doing exactly what it was designed to do at all times.
Carefully flip the air purifier upside down and twist the bottom cap to the unlocked position.
Remove the bottom cap.
Pull out the old filter using the removal tabs and discard it.
Remove all packaging and wrapping from the new filter.
Insert the new filter and replace the filter door. Twist the filter door until it clicks into place.
Carefully return the air purifier to the upright position, plug it back in, and turn on the power. Calibration will begin.
After installing a new filter, press and hold the Filter Life button on the top control panel for 3 seconds to reset the filter life percentage. The unit will beep when the filter life is reset to 100%.
Eine weitere Person hat diese Anleitung absolviert.
