Einleitung
The Shark Clean Sense Air Purifier has a hard protective shell that keeps its components safe. This is a prerequisite guide for disassembling the device to get to certain parts and can be used as a guide to replace the shell.
Was du brauchst
Unscrew the one 1.2 cm screw holding the grate at the top with a TR10 Torx screwdriver.
Use a prying tool to carefully pry along the outer edges to disengage the inner retaining clips.
Remove the grate.
Flip the device over and unscrew the bottom by turning it clockwise.
Remove the filter.
Remove the five 1 cm a Phillips screwdriver.
Unscrew the four 1.2 cm screws with a TR10 Torx screwdriver.
Make sure that you are pulling up on the side that allows, as pictured in the red box.
Gently slide the cases up and down, or hold one and gently pull up on the opposite side (Down on the left, up on the right for this picture).
Gently open the case outwards as there are fragile electronics inside.
Remove the fan housing.
Eine weitere Person hat diese Anleitung absolviert.
