Zum Hauptinhalt wechseln
Shark Cordless Pet Perfect Battery Replacement
Was du brauchst
  1. Shark Cordless Pet Perfect Battery Replacement, Battery: Schritt 1, Bild 1 von 3 Shark Cordless Pet Perfect Battery Replacement, Battery: Schritt 1, Bild 2 von 3 Shark Cordless Pet Perfect Battery Replacement, Battery: Schritt 1, Bild 3 von 3
    • Remove the Dust Cap Container then remove the 7.5mm screw (with the PH2 Bit) from the battery cover.
    • Using a black spudger pry open the cover, and remove the cover plate.
  2. Shark Cordless Pet Perfect Battery Replacement: Schritt 2, Bild 1 von 2 Shark Cordless Pet Perfect Battery Replacement: Schritt 2, Bild 2 von 2
    • Once the battery cover is removed slide the battery mount upwards and pull it out.
  3. Shark Cordless Pet Perfect Battery Replacement: Schritt 3, Bild 1 von 3 Shark Cordless Pet Perfect Battery Replacement: Schritt 3, Bild 2 von 3 Shark Cordless Pet Perfect Battery Replacement: Schritt 3, Bild 3 von 3
    • Pull out the battery and then disconnect the battery at the quick disconnects.
Abschluss
3 weitere Nutzer:innen haben diese Anleitung absolviert.
USF Tampa, Team 16-2, Blackwell Spring 2017 Mitglied von USF Tampa, Team 16-2, Blackwell Spring 2017
USFT-BLACKWELL-S17S16G2
4 Mitglieder
11 Anleitungen geschrieben
4 Kommentare
Throw it away and buy new lithium Pet Perfect
John Carson - Antwort
I changed the battery, it still shuts off after 1 second
Garry - Antwort
It has a 2 year warranty, mine quit working at 2 years 10 months. Pretty expensive for only 34 months.
Ralph E Beaver - Antwort
Mine still working after 3 (three)years and it was $45 at the time from Walmart. Wouldn't be cheaper to buy an other whole unit than waste $45 plus tax, plus work just on the battery pack like Amazon's Banshee ( read EXTRATERRESTRIAL ) battery pack of $45 plus tax ???
Aurel Tita - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 41
Letzte 30 Tage: 121
Insgesamt: 13,905
