Zum Hauptinhalt wechseln
Shark Cordless Pet Perfect Front Belt Replacement
Was du brauchst
  1. Shark Cordless Pet Perfect Front Belt Replacement, Front Belt: Schritt 1, Bild 1 von 2 Shark Cordless Pet Perfect Front Belt Replacement, Front Belt: Schritt 1, Bild 2 von 2
    • Remove the two 12mm screws from the front face plate with the PH2 bit from the tool kit.
  2. Shark Cordless Pet Perfect Front Belt Replacement: Schritt 2, Bild 1 von 3 Shark Cordless Pet Perfect Front Belt Replacement: Schritt 2, Bild 2 von 3 Shark Cordless Pet Perfect Front Belt Replacement: Schritt 2, Bild 3 von 3
    • Once the screws are removed pull the front face plate off. This will allow access to the belt and motor.
  3. Shark Cordless Pet Perfect Front Belt Replacement: Schritt 3, Bild 1 von 3 Shark Cordless Pet Perfect Front Belt Replacement: Schritt 3, Bild 2 von 3 Shark Cordless Pet Perfect Front Belt Replacement: Schritt 3, Bild 3 von 3
    • Lift the brush roller upwards towards you, and the brush roller should come out along with the belt.
  4. Shark Cordless Pet Perfect Front Belt Replacement: Schritt 4, Bild 1 von 2 Shark Cordless Pet Perfect Front Belt Replacement: Schritt 4, Bild 2 von 2
    • Remove the belt from the motor mount, and then replace with a new belt.
Abschluss
Ben Dzugen
383 Reputation
3 Anleitungen geschrieben
USF Tampa, Team 16-2, Blackwell Spring 2017 Mitglied von USF Tampa, Team 16-2, Blackwell Spring 2017
USFT-BLACKWELL-S17S16G2
4 Mitglieder
11 Anleitungen geschrieben
2 Kommentare
Nice and simple but where can we purchase the belts?
jmrlachance - Antwort
My shark pet vacuum didn't come with lint brush roller. How do I get one. I buy these pet vacuum for friends/family. Please respond
Tina Cherney - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 10
Letzte 30 Tage: 31
Insgesamt: 2,672
