Einleitung
You may need to replace the LED lights if they do not flash when the device is turned on. To remove the motor, soldering skills are required. See this guide for soldering instructions.
Was du brauchst
Open the garage door by sliding both of the release buttons away from you.
Lift off the garage door.
Remove the plastic screw covering using a metal spudger by pushing the sharp side into the crevice and prying the cover out.
Turn the T10 Security Torx screwdriver counterclockwise to remove the 15mm screw.
Use wire cutters to detach the black cables from the LEDs on both sides.
Strip 1 cm off the ends of the wires, using a wire stripper.
Solder the exposed wires to the new LEDs.
