Einleitung
Soldering skills are required.
Was du brauchst
Open the garage door by sliding both of the release buttons away from you.
Lift off the garage door.
Remove the plastic screw covering using a metal spudger by pushing the sharp side into the crevice and prying the cover out.
Turn the T10 Security Torx screwdriver counterclockwise to remove the 15mm screw.
Using the plastic spudger, pry the back seam of the top component to pop it off the vacuum.
Remove one 15mm T10 screw from the inside left of the base of the vacuum to access the motherboard.
Using the nylon spudger, place the curved side under the motherboard.
Gently pry the motherboard out of the base of the vacuum.
