Zum Hauptinhalt wechseln
Shark ION Robot 750 Battery Replacement
Was du brauchst
  1. Shark ION Robot 750 Battery Replacement, Battery: Schritt 1, Bild 1 von 1
    • Make sure the device is completely powered off before working.
    • On the bottom of the vacuum, unscrew both sides of the vacuum cover using a Phillips screwdriver.
    • Gently lift and remove the cover.
  2. Shark ION Robot 750 Battery Replacement: Schritt 2, Bild 1 von 2 Shark ION Robot 750 Battery Replacement: Schritt 2, Bild 2 von 2
    • Grip both of the battery pull tabs and lift the battery out.
    • Be careful when lifting the battery out because it is still connected to the motherboard.
  3. Shark ION Robot 750 Battery Replacement: Schritt 3, Bild 1 von 2 Shark ION Robot 750 Battery Replacement: Schritt 3, Bild 2 von 2
    • To disconnect the battery, firmly squeeze down on the marked tabs, then pull the connector out of the socket.
Ziellinie
Tuong Tran
196 Reputation
2 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 3
Letzte 30 Tage: 15
Insgesamt: 121
