Einleitung
This guide focuses on the front pivot or caster wheel replacement process on the Shark ION Robot 750. The front caster wheel allows the vacuum to move across the floor and change directions. You may need to replace this part if you notice your robot skidding along the floor, making unusual sounds, or showing visible damage.
Before you begin this repair, make sure that your device is turned off.
Was du brauchst
Fast fertig!
Abschluss
